Zum Hauptinhalt wechseln
Dies ist die kleinere kostengünstigere Version von Samsung zehntem Galaxy Flaggschiff-Smartphone, das im Februar 2019 auf den Markt kam. Es wird mit Android 9.0 (Pie) geliefert.
50 Fragen Alle anzeigen
What is the screw size of s10e? And are they all the same size?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
What part are you trying to repair?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If you open up one of the iFixit repair guides related to the part you're trying to fix, you'll find that the iFixit crew takes the time to measure the length of the screws and put that number into the guide where the screw is removed. Unfortunately they don't measure the thread pitch and diameter, but at least the length is better than nothing.
As an example, I looked at the Motherboard Replacement guide. It appears that all of the screws holding the midframe and the speaker (about 15 altogether) are listed as being 3.9mm, so it does look like a lot of them are the same.
However, continuing on, there are also 3.7mm screws holding down the motherboard, so obviously the majority of the screws are the same, but not all.
If you need replacement screws, you can always get a set from places like eBay, Amazon and AliExpress; you may have to measure them to be sure you're putting the right one in, but it seems like there's not a lot of variety, so just be sure not to use a long one where a short one is supposed to go; many phones have been ruined by doing that.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
곽상권 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 203
