Zum Hauptinhalt wechseln
What's causing occasional loud clicks, but fridge is still working?
My Kenmore Coldspot (mdl#: 106.78222801) has started occasionally making a loud click when the compressor starts (a few times a day). I've cleaned the coils underneath as best as I can (I've cleaned them before as well). I've also checked the fan, and it's clean and spinning freely. The fridge and freezer are both still cold, so I know it's working most of the time. I've also tried turning the temperature setting down to make the compressor come on, and when I do there is no click. So it's not consistently happening.
I'm assuming it's the start relay or the capacitor starting to go out? But how can I tell which it is? Or am I looking at the wrong thing?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The clicking could be the start relay/ ptc / relay. If the start relay/ptc relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start rela/ptc relay.
Here's your part: https://www.repairclinic.com/PartDetail/...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jeremy Adams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 37
Letzte 7 Tage: 261
Letzte 30 Tage: 1,142
Insgesamt: 9,688
