Zum Hauptinhalt wechseln
power connector broken inside
The previous posts were very useful in disassembling the laptop down to teh mother board. Now I need to replace the existing jack which was completely broken and I need to know where I should conenct the +/- connectors of the new jack. It appears that 2,3,4,5 are all connected to the outer connector, but I see no left over connector connecting pin 1.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
Joe, any way you could post an imagine so we know what you are referring to?
von
OT I think this is a continuation of this post.
Laptop does not power on with adaptor
von
Ah, I see. So Joe, if you have your motherboard and the part disconnecting, you can not identify where the new one goes? Did you get the right replacement connector?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here is a link to the service manual for your computer. In it you will find the answers to your questions---it is in pdf format. Good luck.
http://support.acer.com/acerpanam/Manual...
War diese Antwort hilfreich?
Punktzahl 3
Kommentare:
+ and here http://www.insidemylaptop.com/fix-acer-a... are some good visuals about the 5000 series and how to replace the Dc plug.
von
Antwort hinzufügen
Joe wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 3,026
