Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
mac won't turn on or charge
hey,
I have change my battery six month ago with a iFixit kit. Everything was going well.
I am in holiday in the Caribbean, when I plugged the charger the first time (It was running out of battery), I had a very short (0,2s) green light on the Magsafe, then it stopped.
And since my mac won't charge at all (no light), I tried the different NVRAM and SMC, with an other Magsafe charger (a friend have exactly the same mac and doesn't have any problem...) - nothing.
I really don't know what to do now. Asking myself if it's a short-circuit that damaged the battery cause of the voltage difference ? Or just that my mac died on me randomly. Am pretty desperate right now because I have all my work on it.
Please, help me :)
Thanks in advance for your advise !
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
So the MagSafe LED just goes out? Or did it go Amber.
von
It lit just once very shortly, then nothing since !
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@jeanlecerf Unfortunately, you most likely have a bad battery (even iFixit isn’t immune to manufacturing defects). There is a known issue with the chips on the batteries board, that either needs replacing (NOT a DIY job) or a replacement battery. I had the exact same issue with a battery for a 2013 MB Air (not purchased from iFixit).
Get in contact with iFixit support about the problem. They’ll take excellent care of you :)
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thanks for your answer ! How did you do then with your MB ? Changed the battery?
von
@jeanlecerf I luckily hadn’t recycled the original battery, which was still OK-ish, so I put that back and everything was A-OK again. The supplier was out of stock on the battery, so I’m still waiting for the replacement.
von
Thanks you very much. I still also have my original one. I'll try when am back home. Fingers crossed !
von
Try disconnecting the battery from the logic board and MagSafe. Press and hold the Power Button for 15 seconds. Reconnect the battery, the the MagSafe, you should get a spontaneous restart.
Bewertung 2
1 Kommentar:
Thanks. But just tried and nothing new...
von
Antwort hinzufügen
jeannotparis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 109
