Zum Hauptinhalt wechseln
Der Acer Nitro 5 AN515-53-55G9 ist ein Laptop für preisbewusste Gamer, welche 2018 auf den Markt kam. Der Laptop verfügt über einen 256 GB SSD Speicher, eine Nvidia GeForce Grafikkarte und einen Intel Core i5 Quad-Core Prozessor zu einem günstigeren Preis als bei den meisten Gaming Laptops.
Laptop won't turn on.
So, after having a gaming session with friends, i powered down the laptop for the night and went to sleep. I went to class the next morning and i sat down and opened it up.
I pressed power and the keyboard and fans go on, but nothing pops up on screen. My external keyboard lights up but not my external mouse which was weird. I plugged in an hdmi cord to check if it was just the screen but nothing pops up.
I searched the internet with these symptoms and the one that fit the most was cpu was fried.
I wanted to ask you all for your opinion.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Have you tried this:
1. Turn OFF.
​2. Press and hold the F2 key while turning.
3.If the BIOS/Settings screen appears release the F2 key.
4. Tap on F9 key and hit enter key without changing the option.
5. Tap on F10 key and hit enter key without changing the option.
6. It should restart by itself.
Some have found this helps with some models of the Nitro 5:
". . .there is a pressurized micro-switch somewhere in the middle of the keyboard, near the letters X C V D F. I pressed down near that spot and push the power button at the same time, and finally the laptop turned on. For safe measure, I put pressure on the spot below the letters of the keyboard. This also works the same way when typing with other keys on the keyboard. Don't press down too hard, otherwise you may damage the internal hardware." Proceed with caution.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bradley Tounget wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 33
Insgesamt: 615
