Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
help Mr.mayer..T_T ...MacBook ..
coconut battery
current charge 3784 mah
maximum charge 4171mah
90%
battery capacity
current 4171
design capacity 4100
mac model macbook5,1
age of your mac 38 months
mattery loadcycles: 162
battery temp 30.0
this....
help T_T
and , that's
battery on , adatpar on , booting ok
battaery remove, adaptar on , booting X
it's normal...?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Let's see if I have this right. Your machine is booting with or without the battery. Your battery is charged to 90% capacity. Your only problem is that it says the battery is not charging right now. If this is correct, then remove the Magsafe and boot from the battery and let it drain to 50% then reconnect the magsafe and see if it charges. If your problem is that last 10% of battery charge, live with it.
War diese Antwort hilfreich?
Bewertung 5
Antwort hinzufügen
ostard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 348
