Zum Hauptinhalt wechseln
Das iPad Air (5. Generation) wurde am 8. März 2022 angekündigt. Es ist mit dem M1 Chip und 5G ausgestattet.
iPad Air 5 charging port replacement
Do the iPad Air 4 and 5 have the same charging port? Where can I find a store that could repair iPad Air 5 charging port? The only store I know cost about £115 but I can not afford it...
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
£115 for a charge port? Is it made of gold? We charge £75 to replace them. I’d find somewhere that doesn’t rip people off.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Yes both the Ipad air 4 and Ipad air 5 have the same charging port, but there is 2 different models make sure to check wether your tablet is the wifi or 4g version. And so you know, that repair has a very annoying solder connection instead of a simple plug unplug connector like your screen has. You will want someone with soldering expirience cause you can easily damage the motherboard if you don't know what you are doing.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Soldering steps are shown in great detail in this video: https://m.youtube.com/watch?v=BZlhqoOobt...
von
Antwort hinzufügen
Jpp Jp wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 16
Letzte 30 Tage: 56
Insgesamt: 1,828
