Can't start after replacing battery
Hi, why my oral b io doesn't work after battery replacement? The guide is fool proof however, something goes wrong.
Thanks for your help
Ist dies eine gute Frage?
Sorry to be late to the party, but a german user just posted a comment with the same problem and the solution: He managed to reset the io via the app and it works flawlessly since then.
War diese Antwort hilfreich?
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 91
Insgesamt: 618
7 Kommentare
Hi @juanpulag,
Did you put the battery in the correct way? Maybe double check.
Did you charge the battery first after installing it, before attempting to turn on the toothbrush?
von jayeff
What battery type did you replace with? Do you have a multimeter?
von Andrew S
@andrewsawesome Hi Andrew, thanks... I don't have a multimeter, so I can say that even the original battery doesn't start the brush.
What can I do with a multimeter? Thank for your answer....
von Diego
@juanpulag I was going to ask you to check the voltage of the battery with a multimeter.
von Andrew S
@jayeff hi, neither new and old battery works, the brush just shut down permanently... So sad, that's was something easy to solve "was"
von Diego
2 weitere Kommentare anzeigen
