Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfĂĽgt ĂĽber Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-AnschlĂĽssen)
102 Fragen Alle anzeigen
MacBook air inverts external monitor screen color
The actual monitor is a Planar PLL2210w
and it keeps inverting colors on a 2020 macbook air, works fine on a dell laptop i have, and a macbook pro also, its just on this, also i tried messing with the monitor settings, the different color settings either made the screen worse or wayyy too bright and at one point the left bottom corner just started glitching
i use a hdmi to ubs-c converter btw
this is what it looks like
this is what its suppose to look like
update
it does this cute thing where it will make white turn green then try to fix itself i guess, then anything that supposed to be white will start flashing between green and white for a few seconds ._.
idk if its the monitor, the laptop, or maybe the converter, and how do i fix it lol
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufĂĽgen
1 Antwort
Gewählte Lösung
Take a few magic mushrooms that should fix things! 🥴
Are you using the same USB-C to HMDI dongle with the different systems?
This MacBook is one of the first systems to use Apples M SoC. What is the other MacBook Pro’s CPU/SoC? That maybe the issue with this dongle.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
the macbook pro is the same year, and im using the same dongle
the macbook pro is M1 also
von
@timtomissus - Time to try another dongle.
von
Antwort hinzufĂĽgen
timtom7777 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 47
