Zum Hauptinhalt wechseln
Die Meta Quest 2 (ehemals Oculus Quest 2) wurde im Oktober 2020 veröffentlicht und ist der Nachfolger der Oculus Quest.
I accidentally spilled a small amount of water on my headset
I spilt a pretty small amount of water on my Meta 2 headset, it was working properly but now it isn't turning on. It still displays the powering on screen, but it won't stop. The controllers won't connect either, but nothing happened to the controllers.
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
yeah same it keeps doing that i hear it turning on but its restarting in the booting screen
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
Just like with all water damage please don’t try and turn it on unless for testing purposes as it can make the issue worse:-)
What I would recommend doing here is taking the device apart and having a good look for where the water got in,the sooner this is done the greater chance you have of your device working again!
Once inside and you have find where the water has gotten in ,carefully clean the effected area(there’s usually corrosion where the water got in)with isopropyl alcohol until the parts and boards are water and corrosion free
After making sure no other parts were effected you can plug it in and test but if it still doesn’t work ,it will need board level repair which isn’t easy unless you have experience in that sort of field
Here’s a disassembly guide
Oculus Quest 2 Demontage
And here’s a water damage guide(this one if a iPod but it’s the same process for resolving water damage)
iPhone Wasserschaden reparieren
Hopefully this helps
Any questions please ask
iPhone Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Meta Quest 2 Oculus Quest 2 Demontage Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Karter Brown wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 1,199
