Zum Hauptinhalt wechseln
Manufacturer Part Number 100015685 Serial Number: G5KDCZ0670L5
The storage section in Settings won't open
The storage section in the device settings app won't open when I tap the button. It will buffer, display the settings gear icon, then return to settings page. All other sections work okay. All other apps work okay. I've reseated the card, restarted, and powered off and on several times with no effect. Any ideas?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @remarkibal
When you say "all other sections work OK", did you clear the Settings app Cache as well? Not sure if this is what you did or not
Go to the Settings menu > find and select Apps or Application Manager > find and select the Settings app > select Storage > select Clear Cache.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Any other fixes? Having this issue as well
von
Ma tablette a un identifiant monté dessus Ma tablette est équipée d'un bypass
Bewertung 0
Antwort hinzufügen
Stephen Mark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 1,876
