I have similar pattern on a Launch PS5. PS5 games crash but PS4 games are all fine. Within a random amount of time of booting any PS5 game (disc or digital) I get a CE-108255-1 or a CE-100996-6 error. Will play movies and any PS4 game fine. No PS5 game of any kind works - neither a 100mb 8bit platformer nor Cyberpunk. PS4 versions of identical games load fine.
Have done every version of database rebuild, usb etc. etc. All the copypasta "ReBuiLD your DatAbAsEs" advice is completely useless. Sony's customer support was a bot that kept forgetting what it had just said.
Tried wired/wireless and different network. Tried anon account. Added an NVME drive and booted a game off of that. Tried all possible graphic settings and switches.
Have gone through many system software updates since it started and none have resolved it.
Took it into a shop and had them professionally tear it down and redo liquid metal. They also swapped PSUs to see if it was something in the power supply. No dice.
The idea it's overheating is incorrect: it happens immediately on startup. It may have been a heat issue at one time, but now there is a damaged chip somewhere. Seems likely it's the APU.
I have had five different shops refuse to repair it or troubleshoot it.
Very frustrated. Will be my last Sony console, and I had them all.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare
Did you fix this issue I’ve seen it in multiple times and everyone they send back it has the same problem
von outinfrance
Did you fix this issue I’ve sent it in 3 times and they send it back with the same problem
von outinfrance
i also did all the possible things i can (rebooting etc.) but my ps4 games always wouldnt work and i cant turn my rtx on.
von Deniz
I have the same problem too but I've watch several videos don't all the steps and methods but none of them work does anyone know what's wrong or what I can do, thanks.
von kai mazhar
