Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage für Samsungs S20+ Android Flaggschiff-Smartphone vom März 2020
Why do I have a blue line on my screen?
Why do i have a blue line in the middle, along the whole length of the phone for afew seconds after screen unlocked?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @kamal_bathusa
Try the following and check if either resolves the problem.
  • Wipe the cache partition and check
  • Try starting the phone in safe mode and check if the line appears or not. If it doesn't, then a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall to see if the problem is still there or not. Once it has gone, then the last downloaded app that was uninstalled was the culprit. A downloaded app is one the you downloaded and installed on the phone and didn't come pre-installed on the phone when you first got it.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kamal Bathusa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 38
Insgesamt: 2,619
