My touch screen is unresponsive after battery replacement
I changed my battery and the battery was draining fast so I got a warranty replacement and put it in my phone... The issue was when I was taking the screen off the adhesive strip got stuck on the ribbon cables for the screen and ended up tearing the black metallic film on the back of the screen!!! I thought nothing of it assuming it is just a ground plain and swapped the battery and turned on the phone. When I did I noticed my touch was not working at all. When I opened up the phone and took off the connectors and checked them all I noticed a very thin and tiny round piece of plastic it was orange and looked like kapton tape in-between the touch connectors. I thought this was the only issue so I removed it and put eye back together and it still was not functioning!!! Please help I have included macro pictures of the connectors.
PS I followed the iFIXIT tutorial but yes I did. My issue was that the battery I bought from iFIXIT was not making a proper connection and the phone would reboot randomly. So I was changing the battery
Ist dies eine gute Frage?
5 Kommentare
Second pic I'd check those 2 components below the connector haven't been knocked loose
von [deleted]
@strongbow I checked that and they look like there are there is just the coating that is missing
von Brian Swanson
Did you try nudging them to see if they move? Definitely need some sort of magnification to check.
von [deleted]
Can you show the part of the “film” that you tore? And, I just want to confirm, you disconnected the battery before messing with the display’s ribbon cables, correct? During reassembly, it’s crucial that the battery is the last component attached as well…
von Luke
@princeunicorn I added the answer and more pictures, hopefully it helps
von Brian Swanson
