Zum Hauptinhalt wechseln
Der Game Boy kam am 21. April 1989 in Japan auf den Markt, dann am 31. Juli 1989 in Nordamerika und schließlich am 28. September 1990 in Europa. Er ist erkennbar an einem großen grauen Gehäuse und der Modellnummer DMG-01
68 Fragen Alle anzeigen
Powering on (red led) but absolutely nothing.
Dmg powers up but no activity on the screen and a low white noise, with or without a cartridge. I’ve seen many repair tips regarding a powering up but something visually. Any thought? What can be ruled out and where to begin? Thanks community.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I have this problem too, I cleaned the contacts with vinegar and then with iso, now it powers on and all you hear is a click coming from the speaker and no sound or picture. I tried headphones and there is just a white noise. I swapped the screen half with a working one and vice versa. The screen half is good and works on my working half with the battery compartment. When I put my good working one in the faulty game it the same thing happens. I’ve cleaned the board with iso, everything looks decent but still no picture or sound. Any ideas?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@bradley007 you did not tell us what you already checked. If we make the assumption that there is power on your GB, I would next check components around the display and the power rails. Something like this
and this one
from here should help with the troubleshooting. Also, the beast got a few miles on it, check all the traces and capacitors for corrosion, delamination etc. Post some good pictures of your mainboard etc. with your QUESTION. That way we can see what you see.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thank you! Will put some pictures uoo ok for reference.
von
When I turn on my TV I have red and green lines vertically running through it how do I get them to go away so I could watch the screen
von
shawn dancy what make and model is your Tv? what have you checked? Do you have sound?
von
Antwort hinzufügen
Brad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 114
