Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
38 Fragen Alle anzeigen
unable to read last block of this device cant reset my iMac
i want to reset my imac because i have dropped it and a white question mark shows up so i watch youtube videos and they dont work because i cannot erase the drive says "unable to write last block on this device" i need help
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I don’t think you reset anything, did you try to restore the OS?
A blinking question mark in a folder is telling you the drive is messed up. This can happen after a good bang or having the system fall over. It doesn’t take much to damage a spinning Iron drive (HDD)
You should bring your system into a Mac repair shop to fix this as you’ll likely need a new drive.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
stxge albert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 50
