Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
142 Fragen Alle anzeigen
M1 Air won't wake from sleep after sitting for a few minutes
Hey All!
Got an M1 Air question. I have one that is basically perfect, but if it sits for a few minutes and the screen falls asleep, the screen won't wake up, although keyboard illumination comes on. If I close the lid, then open, the screen comes on, but simply clicking the pad or a key will not wake it up. I should note that if I try to wake it up IMMEDIATELY after the screen goes off, it does come up, but if I wait 1-2 minutes, then it seems to have gone into a deeper sleep and won't wake up.
Is this a hardware issue? The fact that it works fine in every scenario but one makes me hope it's software. My next step is "revive" in DFU mode, but I thought I'd check here first. It's recently been upgraded from Big Sur to Ventura. Also did a clean install of Ventura just to see, but no luck.
Thanks!
John
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
Tried DFU mode "revive" with no luck. Also, to be clear, there is an image, just no backlight.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @rdklinc
Unfortunately this isn’t much of a solution ( appologys in advance)but more of a indication of what’s causing the issue
As far as I know it ISN’T a hardware issue as my MacBook Pro 15 2014 does the same exact thing occasionally but only in MacOS Bigsur,I have it dual booting Bigsur and Mojave and it won’t do it on Mojave
I would report it to apple as a bug as it could be a software issue that can hopefully be fixed soon:-)
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks! Massively different hardware between 2014 and 2020 M1 though, not sure there's enough commonality to draw the comparison? 2008 15" Pro does this as well, and PRAM reset helps, but M1 has no PRAM.
von
@rdklinc
There is a massive difference
I have seen intel macs that won’t restart properly (press restart and it turns them off rather than restarting them) but that was due to it having a bad battery if all things
Might be worth having a look at the battery condition but I doubt that’s the issue as the machine is still very new
von
@rdklinc - Have you tried connecting an external display with the display assembly closed? See what that does. If the external works correctly then try raising the display assembly, did it even flicker?
The issue is clearly in the backlight logic but the Hall sensor logic also plays into this as it’s roll is to turn off the backlight when the display assembly is closed.
Bewertung 0
Antwort hinzufügen
rdklinc wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 222
