Zum Hauptinhalt wechseln
Reparatur- und Demontageinformationen für das im Oktober 2021 veröffentlichte Pixel 6 Pro-Smartphone von Google. Die Modellnummern sind GB7N6 und G9S9B16.
New screen replacement sticks out of frame about 1 mm
I just bought the ifixit Pixel 6 screen replacement and used the guide to do the work. In the end, everything is working, except my new screen seems to stick out considerably compared to the original. Is this normal? Did I forget a step or something?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Chip,
I have a 6 Pro, but fortunately haven't had to open it up yet, but I did work on my Pixel 2. I've gone over the screen replacement guide and there are only a couple of possibilities I can see.
First, was there anything unusual about the replacement? Did any step not go as described in the guide? As far as the screen sticking out, the only possibility I can come up with would be if you had separated the plastic frame that's mounted on the display and left it on the phone instead of coming off with the screen. I'm not giving that a high probability of being the answer because the guide tabs on the frame wouldn't have any place to go into since the old frame would already be filling the holes they're supposed to go into. So unless you cut those tabs off the replacement frame, then that's not likely to be the problem.
I'm assuming you followed the guide and made sure to clean all the old adhesive off the frame before mounting the new screen with new adhesive. If not, I suppose it's possible the combined thickness of two layers of adhesive might account for it, but that seems like a stretch too.
My next thought was that it may be a screen from a manufacturer that was different from the original, but iFixit only sells genuine Google Pixel parts. As nearly as I can tell, the screen is most likely manufactured by Samsung, although I've seen a few posts that indicate LG has made screens for the Pixel line, but nothing that indicates they made them for the 6, though.
Does the screen sit securely on the frame? Is there any gap between the edge of the glass and the phone's frame? If it seems to be secure and there's no gap, then I might be tempted to chalk it up to a possible change in manufacturers with slightly different dimensions; I know that's common on aftermarket iPhone screens, so it's possible Google has multiple sources for their displays.
The only other thing you can do is open it back up (have another adhesive sheet on hand, of course) and see if you can find anything that looks like a possible source of the issue. Perhaps some adhesive got down inside the mounting tabs that's keeping them from seating fully, for example.
However, if the screen is secure and seems to be sealed well, I would personally be inclined to leave well enough alone, unless it's really bugging you and you just can't live with it.
Good luck; let us know what you decide.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thank you very much for your time on this very detailed response. It helped me realize that infact I think I actually did what you mentioned about the plastic frame being left on the phone! I watched a youtube video and looked at the screen that I have taken off and there is no frame at all. I have ordered more adhesive to give it another go! Thank you again for this help, I think you explained exactly what I did wrong.
von
@Chip Guthrie Well, you're not alone. I haven't done that particular mistake myself (plenty of others though!), but we've seen quite a few iPhones on this site where that's what happened.
Anyway, glad to hear we got to the source of the problem. Now that you've been through the procedure once, it'll go a bit easier the next time.
Pay attention to the warning on Step 4 of the Screen Replacement guide:
Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
Google Pixel 6 Display tauschen
Come back and let us know how it goes once your adhesive comes in.
von
Antwort hinzufügen
Chip Guthrie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 1,072
