Zum Hauptinhalt wechseln
Repair and additional information for the Samsung RF31FM*SB** refrigerator, a bottom freezer model introduced in 2013 with both door and drawer access and an automatic defrost feature. This page covers information for model numbers matching the pattern RF31FM*SB**.
1 Fragen Alle anzeigen
Samsung French 4 door fridge not cooling, freezer not freezing
It started as the freezer was not freezing anymore.
No error codes
Now no freezer and no fridge
Changed:
fridge evaporator fan
freezer evaporator fan runs fine
freezer thermostat
freezer defrost sensor
At my wits end
I am headed to the 2 cpu boards but its a substantial investment to be wrong
HELP please
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Please give us your model number
von
Have you checked if the compressor is running? Is it getting voltage? If the compressor is getting voltage but not running, is the compressor hot? If so, let it cool down and once cool do an amperage reading when you try to power it on. If reading LRA (you'll find this on the compressor data tag) then look at start components.
If the compressor isn't hot, you'll need to ohm out the compressor. Start+run should be close to (start+common)+(run+common). If common is reading OL, try giving the compressor a whack. It's possible the thermal overload is stuck. Whacking it may get it to go back. But then you need to see why did it trip? It's normally the same as when you find a hot compressor with voltage that isn't running... the start components may have failed. You can try looking up the model number of the compressor to find the HP rating, then use a 3in1 start kit. I say this because most people do not have a meter capable of reading start capacitors. Now, if you ohm out the compressor and get OL from start to run, or common to start or run, and can't get the thermal to close... then you'll need a compressor. Sorry... might be a little all over the place. Tired so not sure how comprehensible that answer is.
von
Samsung RF31FMESBSR
The compressor runs, the red light on the control board is on
von
Einen Kommentar hinzufügen
1 Antwort
There is a recall, will repair free call Samsung
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Al Berdun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 282
