Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
no touch ID message
i have an iphone 7.
worked fine. OEM home button.
for whatever reason, suddenly the touch ID stopped working, but home button function was fine. don't really care because i don't use Touch ID anyway. would routinely see the "Touch ID - Unable to activate Touch ID on this iPhone" message when i power cycle the phone. no big deal.
now i see
TOUCH_ID_ISSUE_NOTIFICATION_TITLE
TOUCH_ID_ISSUE_NOTIFICATION_TEXT_IPHONE
TOUCH_ID_ISSUE_NOTIFICATION_CONFIRM
basically the same message as the prior messasge but the meta instead of the real content.
any idea what's going on here?
anything i should do to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Personally, I'd probably start with a complete wipe and restore to eliminate the possibility of a software error. After that if it continues you're pretty much down to replacing the home button, which of course will kill off Touch ID permanently. Unfortunately I'm hearing tales of newer versions of iOS automatically turning on assistive touch when it detects the non-original home button and people have had virtually no luck getting rid of the dang on-screen home button once it starts showing up.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@dadibrokeit
Hi Jerry,
LOL yeah, i was one of those reporting that "helpful" new IOS feature. :)
i figured if the whole button has gone bad i will need to replace it. i've gotten myself a JC V1SE programmer and am searching for that one make/model of home button that will take the programming and hopefully fool IOS's "let me turn on Assistive Touch for you whether you want it or not" feature.
it's already at the highest level of IOS, so i'll need to do an anti-recovery flash with 3uTools, so i'll post how that goes. was hoping for something simpler, but it's Apple. :)
Thanks
von
Antwort hinzufügen
B C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 557
