Zum Hauptinhalt wechseln
The Panasonic Lumix DMC-G7 is an entry-level mirrorless interchangeable lens camera released in May, 2015. The camera has a 16MP resolution and is capable of 4K video capture. The model numbers are DMC-G7 in most of the world and DMC-G70 in Europe.
13 Fragen Alle anzeigen
Menü and other back buttons doesn't work.
Hello, i buyed the camera used and it got one time opened and the screen cable was not good so I replaced it and it's working now but all back buttons doesn't work.
I can't enter the menu or other things nothing happens. The connector and the flex cable looks good tried 5 times to put in and out the cable but nothing happens.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
It's possible that the issue with the camera's back buttons not working is due to a problem with the circuit board or a software issue. If the connector and flex cable are both in good condition and properly connected, then it's likely that the problem is not with the cable.
One solution you could try is performing a factory reset on the camera to see if this resolves the issue. If not, then it may be necessary to take the camera to a professional repair service to diagnose and fix the problem.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Andreas S. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 373
