Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für LG Smart TV. Hier findest du alles, was du für deine LG Smart TV Reparatur brauchst.
20 Fragen Alle anzeigen
Dim grey screen, no picture, good sound.
Hello,
I have an LG 55 inch smart tv, 55UK5090PUA. The screen suddenly went from a solid picture to a dimly lit grey screen. There was no transition where it was intermittent - it just stopped displaying a picture, although when I pressed hot buttons to get to a streaming service, I could hear the sound.
After trying the reset/troubleshooting, I replaced the Main Board with the same replacement part (EBT65513202), plugged everything back in, with the same results. I guess now I have a back-up.
Does anyone have a suggestion on what I should check next (and how)? With the back off the TV, you can see the back lights on for sure, so I believe there is juice moving through the power board.
Thank You in advance,
Evan
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I don’t understand what I did, but I found this YouTube video of a guy that ended up blocking one of the paths on a flex cord that was shorting out between the screen and T-Con … and it worked for my issue too.
Here is the link, in case anyone else has the unanswered problem similar to mine. I’m sure there is a more permanent fix with new parts, but I’ve spent enough time and money on this TV already, so I’m going to call it good.
https://youtu.be/tCknTVbZ3I8
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Evan Winney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 31
Letzte 30 Tage: 104
Insgesamt: 4,456
