Zum Hauptinhalt wechseln
How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
von
Einen Kommentar hinzufügen
3 Antworten
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
War diese Antwort hilfreich?
Bewertung 0
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
Bewertung 0
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
Bewertung 0
Antwort hinzufügen
stephanie l wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 52
Insgesamt: 556
