Zum Hauptinhalt wechseln
Released in Sept, 2018 by OPPO
WiFi, Bluetooth and Hotspot not working in my Realme C11
How do I fix them please?
Ist dies eine gute Frage?
Bewertung 9
3 Kommentare
Hotspot is not playing from my phone to desktop
von
Signal lost connection
von
To change display
Battery change
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If you're experiencing issues with WiFi, Bluetooth, and Hotspot on your Realme C11, there are several steps you can take to fix the problem. First, check your network settings to make sure that these features are enabled. You can also try restarting your device or clearing the cache and data of the affected app. Additionally, ensure that your device has the latest software updates installed. If none of these solutions work, you can try resetting your network settings or performing a factory reset on your device. However, it's important to note that a factory reset will erase all data and settings on your device, so be sure to back up your important data before proceeding. If the issue persists, contact Realme customer support for further assistance.
source
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I'm doing all but still same problem
von
Charging problem
Bewertung 1
Antwort hinzufügen
Tobias Muchiri wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 45
Insgesamt: 2,844
