Zum Hauptinhalt wechseln
Refresh of the original BlackBerry Bold. Known in some circles as the BlackBerry Bold 2.
18 Fragen Alle anzeigen
Water Repair Bold 9700
How I Can Repair A Water Damage?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
Bewertung 0
Antwort hinzufügen
Guillermo Eirin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,114
