Zum Hauptinhalt wechseln
Cheap & Cheap Asus E410MA-EK945TS 14 inch laptop for everyday use, introduced May 14, 2020. CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.8GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
Laptop does not turn on when it's unplugged
Hi, my laptop won't turn on when it's unplugged. The problem should be in the battery, can I fix it myself or should I go to a place?
How can I fix it myself?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Buy a new battery
von
If your laptop won't turn on when it's unplugged, it is possible that the battery is the problem. Before attempting to fix it yourself, you should first try some troubleshooting steps to see if the problem can be resolved without having to open up the laptop or replace any parts.
Check that the battery is properly seated in the laptop. Sometimes the battery can become loose and this can prevent the laptop from turning on.
Try charging the battery for several hours and then see if the laptop turns on when it is unplugged. If the battery is completely dead, it may need some time to charge up before it will work.
If the battery is old or has been used extensively, it may need to be replaced. Most laptop batteries are designed to last for a certain number of charge cycles, and then they need to be replaced. Look up your laptop's model number to find the appropriate replacement battery.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Ariadna,
Assuming you've checked that your charger is indeed working, then yes, the battery is the next logical part to suspect in a situation like yours.
The good news is that replacing the battery on your laptop is actually pretty easy compared to some. I don't have any iFixit-style step-by-step guides for you, but there's a YouTube video that shows the process pretty plainly and will easily get you through the process. If you can wield a screwdriver with any degree of confidence, you can replace the battery yourself. Here's the video.
ASUS e410 Battery Replacement guide, STEP by STEP - YouTube
You can search around for a replacement battery; they look to be available on all the usual sites like Amazon, eBay and AliExpress; pick one that works for you based on shipping times vs. cost; Amazon is usually the quickest but not necessarily the best price, AliExpress tends to be the cheapest but has the longest delivery times, and eBay is normally somewhere in between. Here's one of the first ones that came up when I did a search.
Amazon.com: ZTHY B31N1912 C31N1912 Laptop Battery Replacement for ASUS VivoBook 14 E410MA L410MA E410KA E510MA E510KA F414MA L510MA R522MA E410MA-EK026TS EK018TS L410MA-BV058TS E510KA-EJ033TS E510KA-EJ033TS 42Wh : Electronics
War diese Antwort hilfreich?
Bewertung 2
Here are some steps to try:
Bewertung 0
Antwort hinzufügen
Ariadna Mayol wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 69
Insgesamt: 3,282
