Zum Hauptinhalt wechseln
The Jeep Cherokee is a line of vehicles sold by Jeep under various vehicle classes. Originally sold as a variant of the popular Jeep Wagoneer, the Cherokee has evolved from a full-size SUV to one of the first compact SUVs and eventually into its current incarnation as a crossover SUV.
57 Fragen Alle anzeigen
Jeep Cherokee 87 won't start
1987 Jeep Cherokee Limited four-wheel drive won't start turns over gets fuel has new coil parked it after work went out in the morning wouldn't start ran day before
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@rutor1 did you check for spark on all cylinders? What else did you check?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Rutor,
This almost certainly has to do with your coil or coil wires just based on your description of it happening after a rainfall. Since you just replaced the coil, let’s assume that is good. So, I’d suggest buying a new set of plug wires and the wire that goes from the coil to the distributor (if it is separate…sorry i don’t know this engine by heart). Or, the wire that feeds the coil (12VDC) might be shorting out. Best of luck.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Rutor1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 18
