Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
81 Fragen Alle anzeigen
Why won't HDMI input work after SMC reset?
I had an issue with power input on my Macbook. I connected the charger, and it seemed to disconnect and connect every two seconds. I resetted the SMC, and the problem went away. Only issue is, now my HDMI adapter won't work (throught the USB-C connector). I've tried a different adapter, different HDMI cable, different TV. I also tried resetting everything from the computer, that is SMC, NVRAM etc. Hard reset I haven't tried, but have a hard time believing that would help. Do any of you have ideas what to do, or what might be the issue? I think the USB-C connector might be faulty, but charging works normally?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It sounds like you most likely have a damaged USB-C port. Since there's just the one port on this model it can be pretty frustrating when they fail. I'd recommend following this guide to remove the port and inspect the pins for damage. If the pins are damaged then you should replace the part. Good luck!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jaakko Suomalainen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 9
