It keeps making sounds I don't know from the fan and it keeps crashing
I dont really know what happened,it keeps overheating and crashing and making sounds,it's really weird dude I hope there's a way to fix it
Ist dies eine gute Frage?
You haven't given much detail but it sounds like the fan is covered in dust or is damaged.
This guide is for the battery but it shows you how to take the bottom cover off.
Once the cover is off take a look at the fan. Is it covered with dust? If yes blow off and gently clean off the fan blades. It might be a good idea to turn the system on its side with the top open to a 90 degree angle so it is stable. Press the power button and see if the fan is spinning properly. If not then replace the fan. If yes then test it to see if the overheating problem is gone.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 75
