Zum Hauptinhalt wechseln
Repair and disassembly information for HP Pavilion 15 Laptop PCs, specifically 15-eh models. They feature 15.6-inch displays, AMD Ryzen processors, DDR4 memory and solid-state storage. Released in 2022.
The screen flickers a lot and doesn't change brightness.
It also has a high pitched buzzing sound when the screen is flickering. I'm not sure what could be causing the problem. I updated drivers and it didn't go away. I thought it could be the screen itself but I'm not sure where the buzzing sound is coming from.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Well Screen flickering in Windows is usually caused by outdated display drivers. To update driver you'll need to start your PC in safe mode, uninstall your current display adapter, and then check for driver updates. Start your PC in safe mode and also check for any physical damages to hardware, software problems and bugs in specific applications.
And Also check out this video it might be helpful for you: https://www.youtube.com/watch?v=5Vl3EmyZ...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Aeiou wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 243
