Zum Hauptinhalt wechseln
Die vierte Generation der kabellosen Tastatur von Apple. Herausgegeben im Oktober 2015. Modell A1644.
Not appearing in the bluetooth device
It was all fine, and one day suddenly it will not able to connect wirelessly through bluetooth.
Trying reset the pairing process by disconnect the keyboard, however, since then the keyboard is not discoverable as a bluetooth device, whether one this or other Mac.
However, connecting directly with lightning cable allow it to be able to use the keyboard.
Just that it still not appear in the bluetooth device no matter connecting with cable or not.
Tried restart both Mac and keyboard.
So currently I've no way, but connect the keyboard with lightning cable whenever I need to use it, and it become troublesome and occupy one of my port.
Anyone solution? Appreciate the help.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi @yongjunkhoo
Don't know the keyboard but was wondering if the battery in the keyboard needs replacing.
Here's the Magic Keyboard Teardown (A1644 model) guide that may help.
The battery is being removed at Step.7 in the guide.
Search online for A1645 battery to find suppliers that suit you best.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Yong Jun Khoo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 148
