Zum Hauptinhalt wechseln
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
What SSD can I put on iBook G3 Snow?
What SSD can I put on my iBook G3 Snow (max capacity, type, etc.) and what other pieces (adapter, etc.) do I need to make it work?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@telmoleal looks like people that have done this are using drives like a Kingspec KSD-PA25.1-032ms Storage capacity of the drive may be an issue and it looks like you can get them on here I cannot vouch for the quality of this part since I never purchased it or from this seller. Just an option for you to look at.
Here is some interesting read as well.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
I found that one too and for the price is worth the try. Thank you so much for the help. I'm gonna read that thread carefully.
von
@telmoleal Once you do the "conversion", come back and let us know how it works and if it was a worthwhile thing to do. I am a strong believer in keeping the "old stuff" working for as long as possible.
von
I'll keep that in mind. I believe in keeping the old stuff live their entire life too but at the same time I can't help myself when I find a way to improve something. I've picked the ibook g3 for a classic gaming station and a "typewriter". The noise of the hd is an obstacle for this last one
von
@telmoleal absolutely. Repurposing, fixing and modifying devices to prolong their useability, is what this site is all about. Anybody can buy new stuff and spend tons of money, I am frugal.
von
Hilfreichste Antwort
Boy, had to dust off my old note pad for its notes.
This system uses the older Ultra PATA interface so it will be hard to find a SSD as not many where made back then and the tech at the time wasn’t as good as today.
This is also not a very fast interface so you won’t gain much over a standard plater HD drive. Here’s the guide to get to it as it’s also not easy! iBook G3 12 Zoll Festplatte tauschen
Bewertung 2
1 Kommentar:
There's https://www.amazon.com/KingSpec-2-5-inch... that should work. It's worth the try. My goal is to reduce noise and heat. Performance is not a key issue, just a bonus. Having a good time knowing the inside of a two decades old machine is also a plus.
von
Antwort hinzufügen
fsgdhj wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 250
