Zum Hauptinhalt wechseln
Repair and disassembly information for the Nokia 3.1, an affordable phone with a mixed glass, aluminum, and plastic build released in June 2019.
Why does my phone's apps run slow
Like whenever I enter a app or game it will always be so delayed and the keyboard to and sometimes the app would crash
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Malware and/or system may have too many apps running.
von
The battety runs out quickly
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @juniorkambale
Things to try to resolve the problem:
If it works OK when in safe mode, a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall, to check if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed and wasn't already pre-installed on the phone when you got it.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
junior kambale wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 490
