Zum Hauptinhalt wechseln
Whirlpool Gold Series Geschirrspüler können anhand der Modellnummer WDF750SAYM0, WDF750SAYM1, WDF750SAYM2 oder WDF750SAYM3 identifiziert werden.
Dishwasher won't start
We have a whirlpool gold series dishwasher. On control panel most lights are on but faintly..to start washer I had to push start button twice for it to start..as of yesterday it won't run at all... tried unplugging it for 15 minutes and it still won't run. Any help is greatly appreciated
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
If the lights are dimmer than normal, that would indicate a power supply problem. The power supply is part of the control board. The control board is generally located in the door. It is also possible corroded pins on a connector are causing the issue.
Control boards are not cheap (~$200.) so check everything b4 you purchase one.
War diese Antwort hilfreich?
Bewertung 0
Hit heated dry and hi temp wash 3 times. All lights are bright. Washer runs for a minute then stops
Bewertung 0
Antwort hinzufügen
Ringo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 322
