Zum Hauptinhalt wechseln
The Protocol Galileo Stealth is a quad-copter drone released in 2016. It features multi-directional controls, a 2 megapixel 1280x720 camera, and HD Wi-Fi livestreaming.
6 Fragen Alle anzeigen
Drone tilt's upon takeoff
Drone tilt's to one side upon takeoff
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@angelocenotti got a make and model for this Drone?
von
it is a protocol galileo stealth w/camera
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@angelocenotti,
Have you checked that all the propellers are situated in their correct position and are orientated correctly i.e. not upside down?
usually propellers are marked as to where they should be place on the drone and also what side is facing up.
Most user manuals for drones show how to connect the propellers to the body of the drone
War diese Antwort hilfreich?
Bewertung 1
Check nothing is interfering with the motors on the side that lifts last. One motor isn't spinning up as fast as the others causing the drop in one side. It's possible you may need to fit a new motor. Try a drop of fine oil on the shaft at the bearings incase they are a bit dry.
Bewertung 1
Antwort hinzufügen
Angelo Cenotti wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 91
