Why doesn't the speedometer or any lights work on my bike?
I have a 1998 Suzuki Intruder 1500, the bike will start and run without any issue, but it isn't getting any lights(high-low, turns, brake) and the speedometer and accompaning lights aren't working either. I just replaced the battery and the main fuse relay is fine as well. The only thing of note is the turn signal fuse is popping.
Ist dies eine gute Frage?
I can't say anything about this bike, but on two separate occasions I've had clients bring to me dash clusters from their vehicles, and I found a fault on the ground pin of the main connection. After resoldering those pins to the PCB, dash board worked properly again.
Can you remove your dash to inspect if it is something similar?
von Justin Castle
I'll check it, the cluster isn't that hard to remove. I've had some mechanics I know saying the ignition might be the issue, gonna replace that and see.
von Austin Leonard
