Zum Hauptinhalt wechseln
Apples Flaggschiff-Smartphone für 2020 wurde am 13. Oktober angekündigt und kam am 23. Oktober auf den Markt. Dieser Nachfolger des iPhone 11 Pro ist mit einem 6,1 Zoll OLED Display, einem Kamerasystem mit drei Objektiven und LIDAR sowie 5G ausgestattet.
iPhone 12 Pro restarting everytime it's left to go to sleep
I have an iPhone 12 Pro that I’ve had since release (2.5 years) and it’s off AppleCare unfortunately. It’s been crashing when idle, to prevent it from crashing I have to have music playing constantly. When it does crash it will be bricked for anywhere from 5 mins to two hours. Sometimes forced reset works sometimes it doesn’t. Tried a restore, tried a DFU restore, reset up iPhone from scratch. Apple Store told me to pay $600 CAD for a back unit replacement but they weren’t 100% that that would fix it. I removed the sim and went e-sim and that fixed it for about 45 minutes before it started again.
Reset counter log:
{"os_version":"iPhone OS 16.5.1 (20F75)","bug_type":"115","timestamp":"2023-07-04 23:16:05.00 -0700","name":"Reset count","roots_installed":0,"incident_id":"86B9DEE6-1004-47C7-8864-FC79497CC754"} Incident Identifier: 86B9DEE6-1004-47C7-8864-FC79497CC754 CrashReporter Key: e9ee1cc9517feb23ea9192e05f55c159bd16495c Date: 2023-07-04 23:16:05.57 -0700 Reset count: 0 Boot failure count: 1
Boot faults: rst btn_rst,btn_seq_reset wdog,reset_in_1 sochot,reset_in_3
Boot stage: 0x50 Boot app: 2681261667 socId: 8101 socRevision:
Panic base log:
{"bug_type":"210","timestamp":"2023-07-04 02:54:19.00 -0700","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"A24FFBBD-AE82-49D8-88C9-FCA2E0BEFBC5"} { "build" : "iPhone OS 16.5.1 (20F75)", "product" : "iPhone13,3", "socId" : "8101", "socRevision" : "11", "incident" : "A24FFBBD-AE82-49D8-88C9-FCA2E0BEFBC5", "crashReporterKey" : "d6e60af9641022e05aada86a0c224793b6dcb83c", "kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101", "date" : "2023-07-04 02:54:19.07 -0700",
"panicString" : "Unexpected SoC (system) watchdog reset occurred during sleep/wake transition",
"panicFlags" : "0x0", "bug_type" : "210", "foregroundAppHash" : "2681261667", "repairStatus" : "2", "binaryImages" : [] }
And the important part of the panic full log:
{"bug_type":"210","timestamp":"2023-07-04 01:36:08.00 -0700","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"1D753E8E-40C0-408C-8EEE-D997B43EB392"} { "build" : "iPhone OS 16.5.1 (20F75)", "product" : "iPhone13,3", "socId" : "8101", "socRevision" : "11", "incident" : "1D753E8E-40C0-408C-8EEE-D997B43EB392", "crashReporterKey" : "d6e60af9641022e05aada86a0c224793b6dcb83c", "kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101", "date" : "2023-07-04 01:36:08.47 -0700",
"panicString" : "panic(cpu 0 caller 0xfffffff027ca2610): "port enable failed: 0xe00002d6" @AppleMultiFunctionManager.cpp:1657\nDebugger message: panic
\nMemory ID: 0xff\nOS release type: User\nOS version: 20F75\nKernel version: Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101\nFileset Kernelcache UUID: 84B1F97A4EBB4332AE10EC38FF4B611D\nKernel UUID: 0450791C-9E84-3E6E-9611-412EC38EB3F7\nBoot session UUID: 1D753E8E-40C0-408C-8EEE-D997B43EB392\niBoot version: iBoot-8422.122.1\nsecure boot?: YES\nroots installed: 0
I’m in Canada so if anyone knows Canadian consumer law I’d love to write a letter
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Write a letter? To who? If it's never had one I'd try a new battery.
von
Battery is at 92%
von
I had this problem on iphone7. Once almost 6 month
.. occurred then resolved first time that Maintenance person he changed data ic.. then second time without any interference.. then now a days...
But for every time an explanation that this cause from the hard desk
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
While I can somewhat explain what's happening, there's not a lot of information out there about why it's happening. In your case a timer is going off that's never supposed to; the OS is set up to periodically reset that timer so it doesn't. This is a little different though, as the timer is being triggered not by elapsed time but rather by the sleep/wake transition.
You're right that the port enable failure is a vital clue, but unfortunately it's only useful for Apple; they keep that sort of information close to the vest, so for the rest of us there's no way of knowing what that port is. @flannelist may have some knowledge of the AppleMultiFunctionManager, but unless you've actually worked at Apple again they don't disclose that sort of information.
Regarding the back unit replacement, did you see the other person on Reddit who said they had the same problem that started after they did a back housing and screen replacement?
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I haven’t seen that post, but if it’s a trend with back unit replacements it’s a step closer in finding a solution! Do you have a link?
von
@iphone12restart Yes, I can provide a link, but it was in a response to another post similar to yours and what information I gave was the sum total of what they said. Here you go.
https://www.reddit.com/r/ios/comments/xt...
von
Its the wifi/bluetooth module im having the same issue and i looked into it
Bewertung 0
After checking the Wi-Fi/bluetooth did it work afterwards? @lollol43710
Bewertung 0
1 Kommentar:
No I ended up just getting a new phone unless you wanna get micro soldiering done if advise just to get a new phone like actually
von
Antwort hinzufügen
Bricked iPhone 12 Pro wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 77
Insgesamt: 2,871
