Zum Hauptinhalt wechseln
The Onkyo TX-800 is a solid state receiver that debuted in 1989 and was discontinued in 2002.
4 Fragen Alle anzeigen
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
von
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
von
Laura, thank you for accepting my answer. Best of luck to you....:)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Laura wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 3,796
