Zum Hauptinhalt wechseln
Informationen zur Reparatur, Demontage und Fehlersuche beim Steam Deck mit LCD Display, eine tragbare Spielekonsole von Valve. Veröffentlicht am 25. Februar 2022 und erkennbar an der Modellnummer 1010.
251 Fragen Alle anzeigen
Where can I find parts not on iFixit?
I was doing a full case swap and accidentally broke part MEOJ24900KDL. It's the long ribbon cable that goes along the top vent. I've tried looking in few places but can't seem to track anywhere down to get a replacement. I also suspect I broke the ribbon cable from the display to the motherboard, but I might just buy the upgrade screen anyways, will see. Anyways, whatever help would be much appreciated!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
16 Kommentare
please check that part number
von
@mayer I did check it again and got the same number of the barcode. However I was using Google lens which might be the problem. Im going to try a different barcode reader but for now I just uploaded the pictures if the part and barcode.
Edit:
I tried 2 more qr readers and got the same part number off of both.
von
@drevis25 what else does it say on the ribbon cable? To the left of the FPC....
von
@oldturkey03 Three things, 2248 TSF (in small print) F7A_MIC_FPC, in that order.
von
@drevis25 looks like the Mic Flex. Now just to find it......
von
11 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hey guys I wanted to let you know I bought my replacement from for this eBay seller:
https://www.ebay.com/itm/115989144859?mk...
Mine hasn't arrived yet but I"LL keep you updated once is been installed
(REED DESCRIPTION TO WHICH DEVICES ARE COMPATIBLE WITH !)
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Looks legit!!! You are my hero!!! I'll wait for an update before by but again it looks promising.
von
As soon I get it installed and tested I'll let you know 😉👍
von
Update: Mic Flex (F7A) arrived in great shape and good packaging.
I have made the installation and it worked flawless, I also upgraded the LCD to a 1200P from DeckHD and changed the shell for a clear version from Jsaux.
von
@drevis25 given its a new device, I'd contact Steam and see if they'll let you purchase new parts directly. It may be a while before used parts start showing up on eBay, that usually only happens once warranties start running out.
Bewertung 0
Antwort hinzufügen
Drevis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 533
