Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
If you enable your phone hotspot while in the same room as the TV, does the TV detect that network? Do check your phone settings to make sure that the hotspot is not "hidden".
von Dany
Hi @alcporter,
Does it "see" other WiFi networks OK?
Have you checked that the router's WiFi is turned on if it isn't a dedicated WiFi only router but is a dual Ethernet/WiFi router?
von jayeff
