Zum Hauptinhalt wechseln
Casio's scientific calculator released in June 2015. Uses Classwiz technology and is widely used in exams.
Calculator is in 'PAUSE' mode
The calculation was done in VECTOR mode from the menu. When trying to do something, the calculator hangs, after clearing by the 'ON' button, you can see this status of MENU. Apart from these 3 modes, no other mode is showing, if I want to scroll up or down, the pause sign (2nd picture) is coming on the upper right side.
⁉️ How to get back all mods like before?
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Here’s a quick fix for your calculator:
  1. Press SHIFT + 9, then press 3 to initialize everything.
  2. Next, press SHIFT + 7 + ON. The screen will display "DIAGNOSTIC."
  3. Avoid pressing AC. Instead, press 9.
  4. The screen will fill with 8's. At this point, press SHIFT, then ON.
Your calculator should return to normal! Hope this helps!
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Its work! Thank you for the solution.
von
According to the manual, page 2, you can initialize (aka reset) the calculator by SHIFT 9 (RESET) 3 (Initialize All) = (Yes)
Bewertung 1
2 Kommentare:
Note: this is a duplicate as the answer with the link was marked as spam
von
By the way, @nayemmonir , here you can find the manual
von
According to the calculator manual (see page 2), you can initialize/reset the calculator by pressing SHIFT 9 (RESET) 3 (INITIALIZE ALL) = (YES)
Bewertung 0
4 Kommentare:
doesn't work this
von
@nayemmonir Have you tried removing the battery as @dannish said?
von
yeah, nothing changes
von
@nayemmonir Ok, anyway that symbol means "The display currently shows an intermediate result of a multi-statement calculation." (page 4 of the manual, can't link due to antispam). Maybe is still waiting for input?
von
@nayemmonir Have you tried removing the battery for a few minutes? That may reset the calculator to default settings.
Bewertung 0
2 Kommentare:
I just did but it doesn’t work 🥲
von
It firstly worked but further it shows suddenly and I do the same process flashing doesn't work what to do😕
von
Antwort hinzufügen
Nayem Monir wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 76
Insgesamt: 1,649
