How can I increase my device charging time?
Charging is not working much time . It reduces 100% charge in less than 5hours
Ist dies eine gute Frage?
Cell phone batteries do tend to lose the ability to hold a charge over time so it's not at all unusual that yours no longer lasts as long as it used to after three years of use. The fix is, of course, to replace the battery. On your phone it's relatively simple to do; an opening pick and a screwdriver appear to be all you really need. Here's a video showing the procedure; I might add that heating the rear cover with a hair dryer will help soften the adhesive and make it easier to remove.
realme 7i battery problem / realme 7i battery change / blp803 battery replacement - YouTube
In addition to ordering a new battery, you'll want to pick up a precut adhesive sheet to replace the glue holding the rear panel on; that will help seal it against dust and water once you're finished. You can find batteries many different places; I usually start with Amazon, eBay and AliExpress and anything else that comes up on a search. Here's one of the first ones that came up on my cursory search.
Good luck with your repair; be sure to take lots of pictures and use those to create your own iFixit guide for those who come after you. The community will be grateful and you'll have fun!
War diese Antwort hilfreich?
Caranya dengan Mendinginkan atau menurunkan suhu pada mesin Perangkat, Bisa dengan Heatsink + Coller,atau bisa juga dengan memberi plastik yang berisi air es di bawah perangkat kita
Semoga membantu
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 927
