Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
415 Fragen Alle anzeigen
Bluetooth not working, even after module replacement
I have a MacBook Air early 2017 where I can't activate Bluetooth in system settings (or in the menubar). When clicking the switch nothing happens, stays gray.
  1. I have tried to reset NV-ram and SMC.
    (Other reset options for BT is not available/doesnt show up.)
  2. There is no com.apple.Bluetooth.plist in /Library/Preferences/ to remove
  3. Wifi is working fine.
  4. Same issue even after replacing Wifi/BT module.
    Wifi is working fine. Unable to activate BT.
    Please bring up you ideas on what's the problem or if you have any solution or idea on what could solve the problem.
    Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I'd recommend booting into Safe Mode or reinstalling the OS from Recovery Mode to see if the issue could be a software problem. You could also create a new user account to see if the issue still occurs in a fresh software environment. If you've ruled out software, and replacing the AirPort card doesn't fix the issue, then there could be a problem on the main logic board. It might be worth inspecting the condition of the board to see if there are any signs of corrosion or other damage. Good luck!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks for your answer!
I made a fresh install from recovery mode and then recovered users from a Time Machine backup. But I haven’t tried creating a new user. Will do that!
von
@ola39360 Best of luck! Let us know if you find a solution.
von
Antwort hinzufügen
Ola wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 29
