Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
415 Fragen Alle anzeigen
Sometimes needs the power buton pushed multiple times to turn on
So this is.a bit of.a weird situation, partially because I had this issue once before and fixed it, but don't remember the fix.
I replaced the battery in July of this year and it worked fine for awhile but starting a few days ago I sometimes have to press the power button as many ast 30 times (no, not joking) to get it to turn on.
Now, here's the thing. I did a battery replacement in 2020 and it did this then as well. Worked fine for a few months after the replacement then one day just didn't want to turn on without multiple power button presses.
This happens both when shutdown and if it's in sleep mode long enough OR if I put in in sleep manually rather than just closting the lid.
Now, in 2020, I fixed this but I literally don't remember how I did so and can't seem to find the info now despite multiple Google searches.
What I remember of th 2020 fix:
It involved disconnecting the battery and doing something after that. It's the after disconnecting the battery part I can't remember. I do know that after I did it, I had no problems again until just in the last few days.
The first time I booted the system after performing the disconnect and doing the whatever it was the NVRAM had been reset to the factory defaults, but it was not done via the Command + Option + R + P NVRAM reset trick, beccause it wouldn't power on at all until after the fix was done.
Any ideas on what the fix was I've forgotten?
Additional note: Unlike in 2020, I have access to one tool that helped me realize it is responding to the power button: I have a blink(1) lite that is set to perform a a speciic light pattern when powered on but the OS hasn't taken over control yet. It starts to perform the pattern then powers off after about half a second.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@danj I literally am not talking about the SLI, I made it vey clear I was talking about an external device plugged into the USB port, NOT *any light builtin to the device.
And it's not a weak battery as the battery works fine my friend's macbook air, same model year as mine in fact.
That said, I did finally remember what the 2020 fix was, and it did in fact work: I just needed to remove *all* power for 24 hours. It's working normally now :)
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Right, i couldn't tell that based on your question. You made it sound very different. At least you got it working in the end but make sure you make your questions clearer because you got us all confused.
von
Sounds like the power key has failed. Unlike the Pro series this series uses an integrated key within the keyboard. As such you’ll need to replace the entire keyboard which is not easy! Instead I recommend replacing the upper case assembly as it’s a lot less work! Here’s the needed part MacBook Air 13" (Mid 2013-2017) Upper Case with Keyboard. Then it’s just a matter of transferring the parts over to the new upper case.
MacBook Air 13" (Mid 2013-2017) Upper Case with Keyboard Bild
Produkt
$89.99
Bewertung 0
5 Kommentare:
The power key is actually working. The blink(1) I mentioned, it can be programmed to display a pattern when it gets power until the OS takes over managing USB devices. It starts the pattern, but it fails pretty consistently within a half second, so it does start to power on, it just then powers back off.
And, as I said, I literally had this *exact* issue back in 2020 and the fix did not involve having to replace any hardware.
And, honestly? I can't afford a replacement. It took me 7 months to save up enough to replace the battery this last time, so that's not really an option
von
@joeyteel - let’s get a better idea on what’s happening as the SLI is not programmable it does have a pattern of response but that doesn’t help us during the power on process as you’ve described.
First let’s see if we can get the onboard diagnostics to pop an error code as that can help localize a problem. Restart your system and press the D key to enter. Let us know what you get for the error.
The next is install CoconutBattery and post a snapshot of the apps main window here for us to see.
von
I'm gonna back @danj 's advice and say this is something down to the power button. I'm going to guess what is happening is that the contact patch/membrane is so worn it requires you to press it down hard enough to get it to contact.
To test that (After you've run diagnostics and stuff), what i need you to do is to shut it down, then instead of mashing your power button, i want you to press it, but press it super far in (push it like if your sending it through the keyboard). Let go and see if it works. if it doesn't, then it's likely something further within the keyboard. If it does, then that means your power button does work, it just requires the deepest press to turn on. As long as everything else works, it should hopefully be okay.
von
Let me repeat this concept one more time for you:
Yes, the power button is working. The blink(1) is a device that plugs into the USB port. It will not run the sequence **UNLESS IT HAS POWER** so if it is starting the process, then it is startng to get power.
What is happening, as I said *multiple times now* is that it is indeed starting to power on, but then it turns back off most of the time. It *DOES* work eventually however, it just takes multiple presses for it to turn on *and stay on*.
As I also said before, I had this *exact* issue in 2020, and it was a simple fix that didn't involve replacing the hardware.
von
@joeyteel - We do hear you! So let’s review what Apple engineered here as maybe that will explain why things are not so black and white.
The white Status Indicator Light (SIL) main function is to tell you the system is in sleep mode, this is where the illumination ramps up and down. The next action is a blinking pattern when the firmware can’t pass its CRC (corrupted or the the correct version)
Reference: If the Status Indicator Light flashes on Mac
During the startup it can blink depending if getting external power Vs not connected to a external power source. So it’s a spurious condition that doesn’t tell us anything.
So now let’s drive deeper here what does the onboard diagnostics tell you as well as CoconutBattery?
As we need something more definitive to work from. If the issue is not the keyboard there is only two other possibilities a very weak battery or a messed up logic board.
von
Antwort hinzufügen
Joey Teel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 48
