Zum Hauptinhalt wechseln
Repair and disassembly guides for Acer TravelMate laptops.
Yellowish cycle in the middle of ACER laptop's screen
Laptop ACER Travelmate 4000LMi
Before few days i noticed a yellowish oval shaped area in the middle of my screen. This area can be shown, better, in a white page (picture 1) and even more clearly if look from an angle from above were, because of the angle of view, the white area turns darker (picture 2).
picture 1
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It's difficult to say for sure from your photos, (I know this kind of thing is really hard to capture in pictures from experience) but it's possible this is a sort of screen damage. It's something I see usually in laptops with plastic or more flexible housings.
If something was set on top of the laptop with the lid closed, or it was carried in a bag with other items, then the display may have sustained some damage from the pressure.
It's unfortunate, but in my experience display malfunction of some kind is the only thing that causes this and you'll likely need a new display to resolve it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for help.
I will try to disassemble it to see if there is something like moisture or like that, from inside. The last time i disassemble it, there was a problem on the bottom side of the plastic frame. It does not close 100%. Maybe the liquid i clean the screen (it is a special liquid for screens) passed through this opening. Or moisture.
Hope do not need replacement...
von
Antwort hinzufügen
krakadoros wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 162
