Zum Hauptinhalt wechseln
{A1989 / EMC3214}—Erschienen im Juli 2018. Das 13" MacBook Pro ist mit Quad-Core i5 und i7 Prozessoren und Intel Iris Plus integrierter Grafik ausgestattet.
MacBook not starting after battery replacement
Replaced the battery on my 2018 Macbook Pro Touchbar, turned it on, and it started, Coconutbattery said it was at 100% battery health with 0 battery cycles. I took out the battery, used the adhesive strips to glue it in, and then put it back together. Now, when I try to start it, it shows no signs of life. I've tried reinstalling the battery several times, as well as starting the Macbook while plugged in. Is there anything else I could do? How else can I troubleshoot this issue? Thanks in advance :)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Did you forget to fully shut down the system the second time? Refer to Step 1 in this guide MacBook Pro (13 Zoll, 2018, Touch Bar) Akku tauschen
At this point you need to connect a second Mac via USB-C using Configurator2 App to recover things.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks for the response! It looks like I did forget to disable auto boot before doing the repair. Will I be able to get the Macbook working again? If so, how do I go about doing that. Thanks again!
von
@maximm65709 - You need to leverage a second system to run Confurator2 apps
von
Antwort hinzufügen
Maxim M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 100
