Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
415 Fragen Alle anzeigen
MacBook air pop and dead but no obvious culprit - help please
My daughter’s 2017 Macbook Air made a clear popping noise, no smoke, and then died. No power up or response to SMC or PRAM key sequences. I tried to find a blown component on motherboard or power connector mini-board but everything looks fine. Any suggestions before we head over to Apple store? I have uploaded pictures - thanks!
Pictures after cleaning
Passive components seem ok, I wonder if an integrated circuit can fail with a pop that doesn’t show…
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
While hard to tell I see a questionable area on the backside of the board just below the MLB label just below the string of resistors and capacitors there are a few transistors give the board a wipe to clean off the dust and take a fresh image of this area again.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for looking Dan. I’ll update the post with better pictures. Unfortunately I had to take Humpty Dumpty apart again for the cleaning and new pics and I ended up breaking off one of the wi-fi connector leads so I’ll post a new question for the new problem I created!
von
Antwort hinzufügen
Daniel R wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 43
