Moisture detected whenever phone is put on for charging
Whenever I put on my phone for charging through the USB C port, moisture detection notification comes. But there's not a single moisture on my port.
Ist dies eine gute Frage?
@tahrimbinte8277 if there has been no moisture and if there is no moisture, it is possibly that this is a bad sensor on your charging board. I would start by replacing it. OF course, only do that if there was no moisture.
You could also try to dial (*)#0#(*) (without the brackets ( and) it just did not let me type the asterisks without it) That will get you into the Samsung Hardware Test menu. Check your sensors in there and see what it tells you about failure.
Since iFixit doesn't yet have a guide for this, Use the one from here The charging board is readily available at many online stores. Just ensure that you purchase one for the version of your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 31
Insgesamt: 3,080
1 Kommentar
My S21 was soaked in the port from rain; listening to music during a walking exercise. The moisture warning message occurred for months after drying it gently. Meanwhile, I used wireless charging. I was finally able to use the USB-C port for fast charging without the error message. My guess is tiny wires in close proximity will not tolerate moisture and take longer to evaporate before all moisture evaporates.
von F Dryer
