Zum Hauptinhalt wechseln
Reparatur und Zerlegeanleitungen für den drahtlosesn Sony WH-1000XM3 Überohr-Kopfhörer mit Geräuschunterdrückung
Can't charge headphones, abnormal temperature
I can't seem to charge my headphones anymore, originally I suspected it to be the battery so I bought a new one and replaced it. Turns on fine, battery charge is at 70% but when I tried to charge it it came up with the abnormal temperature code again. I tried charging it on my pc, with the provided cable, or with a charging brick and a powerbank that I have, all do not work. The light stays read for about 20-30 seconds and then it goes flashing again. Now the only thing I feel like I can still do is update the firmware.
At this point I'm basically looking for any ideas on where the issue could lie so I can investigate it and hopefully repair it. So any ideas would be great!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Im having this problem too. Have you found a fix yet?
von
Einen Kommentar hinzufügen
1 Antwort
It could be an issue with the connectors but frankly I don't know that is just a guess in the dark really.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Rowin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 632
