Zum Hauptinhalt wechseln
Samsung Galaxy S21 FE (Fan Edition) ist eine Variante des S21 Models, das am 11. Januar 2022 veröffentlicht wurde. Das Gerät hat kleine Veränderungen im Vergleich zum regulären S21, was das Gerät etwas günstiger macht.
My phone's bluetooth connects to any speaker but no sound comes out
My phone used to connect to speakers via bluetooth with no problem but since the beginning of this year it now it connects to a speaker but no sound comes out. And it's not the speakers because I have successfully connected different phones/devices to the speakers and the sound is just fine. The issue only seems to be related to my phone. Has anyone ever experienced anything similar to this or have any suggestions on what I can do to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
After Bluetooth the WI-FI is gone also. The “breaking” of the phone left right worked for a while but then WI-FI stopped working also. Any tutorials on how to fix this?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
This is a hardware issues, beacuse of low quality components used in the device. Try bending the device left or right in the top part, while something is playing in the background via Bluetooth. Unfort this will cost you more probably a motherboard change!
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I'll have to try and see if that works , if so looks I'll just have to get a new phone 😩
Update: thank you, this actually got it to work but I'm sure it's just a temporary fix. If I were to drop it or it gets knocked around it'll probably go back to not working.
von
yes thats right
von
From past experiences, try restarting the phone and BT sound device, then pair them and try again. If that doesn't work, in your phone settings, in Bluetooth, remove (or "Forget") that BT device, then re-pair the device. If that doesn't work, your phone's BT chip may be at fault.
Bewertung 0
1 Kommentar:
I've already tried both of those but that has not resolved the issue I also reset the network settings but the issue remains
von
I got this very same issue and I don't wanna open the phone because I don't know which part would I need to repair, did you find an fix?
Bewertung 0
Unfortunately, no I haven’t
Bewertung 0
Antwort hinzufügen
Shawniece wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 116
Insgesamt: 2,237
